My Hayabusa seems flat in first and second gear ( especially compared to my GSXR750)
It seems that the timing map in these gears is retarded to tame the bike.
My information suggests that each gear provides a different resistance reading to the ECU
and that the 3rd gear register provides the best advance.
I have cut the "pink" wire and it definitely performs better in second, but I suspect the ecu will then run in the neutral mode which will probably lessen top end power.
I have read the post regarding timming changes on the PCII having no effect on the dyno, I suspect that this because dyno runs are in the higher gear and the ECU is already on its best advance., and further advance lessens power.
Does anybody now how modify the wiring so that the best timming map (I suspect that 3 gear ) applies???
