Rim question
busanostra
I bought a swingarm with wheels. I thought 1st gen busa has 17 inch wheels? My wheels is 18 inches in diameter and 6" 3/4 wide. Before I make mistake buying tires for my reverse trike project, can someone tell me what is the widest tire I can use with this wheels. Do you think this is aftermarket wheel? Thank u
I have a 200/55 Metzler CompK Slick on my 08 right now. Stock rim and stock wheelbase and no problem rubbing anything. Nice tires if you are careful to stay out of wet conditions and ride only when the weather is warm. A taller rear does make the bike turn in easier and is less prone to that flattened oval appearance from center wear. Also adds a lot of weight. There's a one pound difference between a 190/55 Pirelli Super Corsa and a 200/55 Pirelli Superbike Pro which is the same tire in a slick (or so it appeared). --anyway, yes, a full 16 oz heavier for the 200/55 over the 190/55.
