No I didn't take it like that I was afraid you would take it that way from me, but since where okay. The real truth is that the directions have the best info on those specific rings, each manufacture makes them with different metals and percentages which means they each have a unique expansion rate. I didn't even relize actually that response was you I just thought is was someone else chiming in perhaps I was a little defensive. Wether you use a high mechanical compression ratio, Nitrous, Turbocharger or Supercharger you are working for the same thing, cylinder pressure. With an increase in pressure there is an increase in temperature, also your power comes from burning fuel, not from the N2O or Turbo they let you burn more fuel the energy of fuel is measured in thermal units so the more you burn more heat. If this was my engine and there where no directions I would set the gaps as I said in the first response if you look at those numbers provided from the site you supplied they where close. In any event good luck lets see some pics and updates, trying to save my pennies right now to take mine apart talk to you later,
"O"
