Risers and links???
money mike
Hey guys, thinkin about throwin risers and lowering links on the bike when i repaint...
Is this pretty easy, doesn't look hard at all, just wondering, thanks
Not hard at all. Just take your time. You should be able to install them both with simple tools in about an hour.
If you need help, post up when you do it. The only problem you may have is how high the risers are. If you go 3/4 up or so, you may have to re-route your fast idle cable so it does not rev your bike when you turn the bars. The links are easy to install, easier if you have a rear stand, but I have done mine on the side stand. We are here to help you if you get stumped.
thanks alot guys, i very rarely have good info to distribute, so i kinda feel like this site is one sided, but i always appreciate the help that you guys give... ya'll have helped me out numerous times!!!
Its what we are here for, to help each other. :thumbsup:
You don't have to but it's easier with a floor jack and if you remove the exhaust cans if you have the factory set up anyway.
