ccapse
Hi, just wondering if you guys have ever encountered anything like this?
Ive installed a 250-1123 on a Hayabusa gen2 using a CCS100 keypad. It all works perfectly except for one strange trait.
If the unit is turned off, and I apply the rear brake, then when I release the rear brake, the unit turns on - intermittently. My install uses the relay-brake-light option as The gen2 has a LED brake light.
I dont have the issue when I apply the front brake.
The red wire and the activation for the brake light relay are connectd across the rear brake light switch, but front brake switch is in parallel to the rear so it seems odd I only have issue with rear brake.
I Originally had the issue constantly but I swapped to a different relay and now the problem is intermittent.
Both the grounds that go to the relay and the overall ground for the Cruise actuator go to the same bolt on the subframe.
Does anyone have any thoughts on what may be causing this annoying trait?
I know FALQN had a similar issue but he had a brake light modulator installed and my brake light is stock.
Any incites would be much appreciated.
Cheers Chris
Cheers Chris
