Jimingle10
Hi, semi-new to forums hope you can help me!
For quite some time now, when cruising in just about any gear under 6000 rpm, the bike will not maintain the same speed smoothly. It will accellerate very smooth, but when i try to keep it at say, 40 mph....it will buck. A constant off/on feeling even tho im keeping steady throttle pressure. Even if i move the idle increase switch down to act as a cruise control...it still does it. Again this only happens at about 2% throttle, just enought to maintain speed. I noticed my front sprocket is hooked, and ordered a new Driven chain sprocket set that should be here soon. Could this be the culprit?
2nd Question - My fuel guage works from Full - Just before RED. The needle does not go any further, or into the red at all and hence no gas light comes on. Is the arm easy to clean or look at?
Thanks guys!
My bike -
2000 Busa (apprx 16,000 miles)
Yoshimura slip ons (dual)
Everything else basically stock.
Recent Tune Up
-Plugs
-Air Filter
-Brake Pads
-Synthetic Oil Change
Ive had the bike since 500 miles on the odometer....is there any periodic maintenance i should be looking into at 15,000+ miles? My uncle said something about a valve adjustment
Thanks guys!
My bike -
Recent Tune Up
-Plugs
-Air Filter
-Brake Pads
