Hello all. My bike is running rich so i was reading previous posts from others with the same issue, i came across this post..."It sounds like the vacuum line is either off of or is split that goes from the throttle bodies to the IAP (Intake air Pressure Sensor), when this happens, the ECM thinks that the air pressure inside the throttle bodies equals the air pressure that is outside, i.e. WOT."....I went out to my bike and sure enough there is a line that comes out of the far left side of the throttle body and connects to a black and orange plastic piece which was hanging but appeared it was supposed to be plugged into another hose, i plugged it into the hose which hung off the bottom of my airbox and connects to a gold round looking piece, i believe its the iat sensor. Im just wondering if i did it correctly because my bike still doesn't start, but im sure these hoses weren't supposed to be disconnected. There are also 3 other larger hoses which come out the bottom of the airbox almost spaced out like a baseball diamond, one at each corner, the there is a hose connection coming out the front underside of the airbox with no hose connected also, but i didn't see any lose hoses around that appeared to belong on it, any clue which this is for?
