isiahstites
You have forced me to make this public, I tried to work this out with you via PM. However I do not take kindly to being ignored, you have left me no choice.
Here is your ad with your description:
Used Yoshi RS-3 Dual slip ons. I have removed the baffles and packing for a little more throaty sounds. They were nice when I had them on. I switched to carbon fiber ones which I removed the baffles and packing from. These are not obnoxiously loud at all. Yoshi still have quieter slip ons than most even with the baffles removed. I love the sound of my Yoshi's
These are in pretty good shape with a small dent on the underside that you cannot see mounted on the bike. Small bit of rust on the rings that can be replaced for a few bucks buying new ones from Yoshimura USA.
In your add you stated there was a small dent on the underside. As you can see in my photos that there are lots of dings and lots of scratches. I would assume that most of them happened in shipping due to the fact that the pipes, mids nuts and bolts were able to move around due to lack of packing.
The first time I picked the box up to move it the garage and heard the clinking and clanging inside I new it wasn't going to be good. Here is what the box looked liked once opened. As you can see all of your card board separators moved to the top because you didn't fill the box with anything else to keep things in place.
Here is what was under the cardboard. Pipes and mids wrapped once with small, thin bubble wrap.
Here is the plastic bag that held the nuts and bolts, it was empty upon removal and all nuts and bolts were floating around in the box.
Everything removed from the box except the floating nuts and bolts.
Here is the inside of the box, you can see all the gauging in the sides from everything moving around.
