Scorpio alarm sr-i500 elctrical problem
missilelike
I bought a used 2003 busa that had a scorpio alarm on it and it worked great when I bought it. Well last night I went for about a 100 mile ride and as I pulled into the road I live on the problem started, When I turn on the right or left turn signals they both come on like four way flashers and at the same time as they are flashing the alarm chirps simotaniously. The alrm will not activate at all. Strage thing to happen, just thought maby someone would have an idea what might be going on?
Crazily enough I had the same thing happen to me! I found there to be impedance from another wire contacting the wires as they ran to the taillight. Separated the wires and wrapped in electrical tape and the problem was solved.
Make sure the two extra wires in the tail area are hooked individually to t.s. wires and problem will be solved.
Figured it out, It was a bad connection to the battery, thanks for the reposes it gave me a place to start looking
