CrashBomb
Seeing as I've got it apart anyway (well, mostly) I've just about talked myself into a hairdryer over the winter. I haven't seen very much talk about turbo AND big bore (1397) but that's what I'm considering. I want to do it once and do it right. I think I've made my mind up on the Ghetto stage I kit because it's completely concealed by the stock bodywork. I also like the full pipe idea because dump pipes just aren't my thing. I'm not going to mess with the aerodynamic perfection that Suzuki's engineers came up with in the first place.
Anyone out there running a stage I with a 1397 (stock length swing arm)? I know it's going to be a handful but hey...that's kind of the idea isn't it?
My questions are many, of course, and I will be calling Motorhead but I'm going to throw them out here first.
1. Stock compression is around 12:1, right? So if I build a 12:1 compression motor it'll take (roughly) the same amount of boost, yes? I'm not going to run more than 5-7 pounds and for the amount of road I've got around here that's going to be plenty.
2. I can't find a definitive answer, but looking at the pictures of the Ghetto kit it doesn't look like you have to pull anything off to change the oil filter. True?
3. Does anyone have a sound clip of the Stage I with the full exhaust, I'm curious as to what it sounds like compared to a straight dump.
4. It looks like a lot of people have been experimenting with H20/meth injection in lieu of an intercooler. I've been wondering if there's any feasibility to using a small amount of nitrous sprayed somewhere between the turbo and the intake for the same purpose. I know, I know windshield washer fluid is much cheaper but I've got a spare nitrous kit and I've always got plenty of N20 around from other vehicles and I'm talking about using a very small amount. It probably isn't necessary for the boost I'd like to run but I'm mostly thinking academically anyway.
5. Originally I was thinking of swapping the exhaust cam for a stock intake when I put the big bore together but with more duration and overlap won't this actually hinder a forced induction motor?
6. I've worked on Supras that have a blow off valve that can be set to reroute back into the intake instead of the atmosphere. Who makes these? I know a lot of people love the bov sound, but personally I hate it. It's amusing for about a week and then it just gets obnoxious and annoying.
7. Anything else I'm forgetting or failing to see?
Be patient with me fellas. I'm sure I'm going to have a ton more stupid questions, but I'm only about an hour from Dennis in Cleveland (he is in Cleveland, right?) so he's going to have it worse than you with me chewing his ear off with various junk.
Thanks a ton in advance, the motto for the coming 2007 riding season is going to be turbocharged 1397 or bust.
