OB_Cisco San Jose
I've posted this once on Yosh old Hayabusa site,but I think it should be posted here.I work at nights sometimes and since I ride my motorcycle everyday to work I carry a 6ft 1/2" Krypto cable that has a loop on both ends which fits in the back trunk,"you put one end in first and coil the cable in and force the other end in",I also have a disc lock"bright orange type" and one 6 or 7" krypto U-loc and one motorcycle cover.When I get to work I loop the cable around a pole and run the U-Loc betwee the rear right side upper swing arm brace and also run the cable thur the rear wheel if I have enough length and secure the cable to the U-Loc.The front wheel gets the Disc lock and on the bike bag I have my last name painted on the bag with a very large Warning sticker which reads "INSURIED BY GLOCK" also have a picture of a gun on the sticker just in case the guy can't read English.Tried the alarm but no one pays any attention to the alarm unless you have one of those beeper alarms.I also carry a buck knife in case I see some theif trying to steal a bike and is putting it in a truck or van,I slash their tires.Anyways I hope this helps some one out there.Oh ya the cable,U-lock,Disk lock fits in the trunk and the bike bag I secure to the back seat"if your using one" via a nylon adjustable belt that is run thru under the seat and comes up and you fold your bag in a nice small square shape and snap the belt shut and adjust the belt to secure the bag.If you are using the hump you might need to cut the plastic under frame out to make your bike bag fit.I know when I had my TL-R the bike bag would fit in the Hump.I don't under stand way they did not design the Hump like the TL-R,maybe because of the complaints from alot of TL-R owners who had their hump pop off when hitting a bump in the road.Good luck
