Doesn't it also allow you to use the turn signals simultaneously as "hazard flashers"?I purchased the Signal Minder from Kisan Technology. Fairly simple install. Came with good directions. Only have to cut one wire. It allows you to also make your turn signals into running lights with two levels of brightness. You can order it through most local bike shops. www.kisantech.com
Hope this helps.
IF you are running all T/S lights as "running" lights, you may want to consider converting them to LED... I smoked a set of rear T/S housings like this.. The conventional bulbs generated to much heat for the itty bitty housings to dissipateJust installed the Kinsan signalminder with running lamps and brake flash.
Set for 20seconds, then they cancel
All turn signals are now running lamps.
Brake light and rear turn signals flash then go steady burn with brakes
Nice set up but has a few drawbacks.
When timer ends you have to push turn signal cancel to reset the timer.
4 ways start the timer, so if you need them they will cancel when timer ends.
Turn signals will not work if you leave four way flasher button on.
I don't see this as a big problem.......brake light stops the timer. If i needed the 4 ways just put something on the front brake lever to turn on the rear brake and stop the timer.
Not on the California modelThey have turn signals?
<!--EDIT|newredboosa
Reason for Edit: None given...|1098508153 -->
Signal Dynamics also makes all those modules. (Kisan's coke-pepsi competitor) http://www.signaldynamics.com/
Little sidebar, I've used these modules for years but with my undertail on the Busa, the module that turns the turn signals into running lights, the aftermarket undertail wasn't designed to have the bulbs on all the time & kept melting the turn signal housing thingy. Finally just removed the module. Work just fine if you have stock turn signals though.
There are several variations of these modules, Back Off, Brake Hold, Wig-Wag, etc. They all do different stuff, just go with one that works.
I'm also a huge fan of the Headlight Modulator, which both these companies make (I've used both).
I never had a problem with forgetting to turn them off until the busa. Every other bike I've had I could see them and so I never left them on but the busa's windscreen obstructs my view of the dash indicaters so I forget to turn them off all the time. Maybe once I get the double bubble on there so I can see when they're flashing.???
