Puzzled
I'm getting my butt kicked trying to set the TPS sensor. Here is what I've done-tried. I installed the TPS sensor, jumped the connector in the rear of the bike to get the LCD display to show the TPS setting mode, started the bike and set the idle to 1150 RPM, attempted to move the TPS sensor to get the lines on the LCD to move to the center. No luck.
If I remove the sensor and move the internals I can move the lines but not to center. I can change the idle but not the line!
Any suggestions? What am I missing? Should I be doing this with the bike running? Bike Off? I'm stumped.
