Frank--I got your phone message, but late yesterday. We were riding-after more map changes since the airbox mod. Things are good now.
Anyway, its not that easy to post the settings. There are approx. 100 changes. Remember for 0%,2%,5%,10%,20%,40%,60%,80%, and 100% throttle positions and for every 500 rpm increment up to 11000 rpm there is a place in the map table for a change in fuel delivery. Its a dual map set-up. 0%-5% is the low end map and 10%-100% is the high end map.
The easiest way for me to send this is by sending the Power commander 2 file by e-mail. You can also pick up DynoJet's settings from their website. I modified the Micron full system, stock air filter map (M304-003). But, it is a good starting point. If you have the DynoJet software you can open these files. Without the software i would have to copy the settings from the table into a spread sheet or do it by hand and fax it to you. Which is O.K. as long as you have way to enter the settings into the stock ECM or maybe you have a different set-up now?
Let me know, I can do either for you.
Bob
