shift lever adjustment
kjkblade
How do you adjust the height of the gear shifter? I have checked the search can't find anything.
Thanks
There are two ways depending how much adj you need.
1) Loosen the two lock nuts on either end of the shifter linkage. Turn cc or ccw and watch to see which way the lever goes.
2) If you need more adj, you can take the clamp of the transmission shaft and rotate it one tooth cc or ccw depending on which way you need to go.
Hope this helps.
Don
