Without getting into a long response, I'll give it a shot.
I believe the tach is off, mine goes to 11,200 before limiter. I think the limiter is 10,7 to 10,8K. JC thinks the boxes vary, he may be right.
My 1st run on the busa @ the track was 10.01 @ 133mph. Short time was 1.59, speed was low from shifting at 8500rpm, I increased shift points about 500 rpm each run at ended up with speed in mid 140's shifting at 11K+ on the tach. Of course the times went down too.
The key to best times is to maximize "average" power. This is determined by noting the lowest and highest rpms during shifts, and their corresponding hp. Then average these figures. As noted in an earlier post, the best shift points vary with the gear change. This is due to where the engine falls back to after the shift. Also noted earlier is the ram air effect, holding peak power longer.....
Dave
