Well I read that it's good to shift at 80% of the engines redline. In the case of the Busa that would be about 8700 rpms. Because consider that your max torque is at 7,000 rpms. There is also a point where power and torque peak and then begin to fall. Get a print out of a dyno run. It has the graph of engine speed, torque, and power. my 2 cents
Uh....that's fine and dandy if your in a 5.0-liter mustang but in the BUSA world, that doesn't mean/do anything but make you run slower!
10,600RPM is optimal but most factory tach's are off so you will have to take it to RED-LINE to find out what yours reads. FUEL cut off is 10,800 so you want to get as close to that as possible.
My tach indicates 11,200 before fuel cut off so......I take it as high as possible without hitting the limiter. I usually shift around 11,000-11,100!
If you don't believe me, take it to the track and watch your times drop and MPH go up the higher you shift!
Josh
