Shifter seal?
Hey guys I have a 2005 busa 5000 miles and it appaears to be leaking fluid where the foot shifter goes into the housing. It looks like it has a black seal there that its leakinfg from. Is this just a press in seal or is there more to it? Also when i pull this seal will it drain alot of oil? Thanx brothers
that seal is pressed into the shifter cover, remove, clean areaand press back in new one.. I have removed everything and just cleaned it before as it gets grime in it..
SEAL,OIL,13X22X
09283-14006
GASKET,GEAR SHI
11485-24F00
If it's seal where the little rod is motor has to come out..if it's splined one clasp is on do as above..
i just did one over the winter i pulled the shift cover but theres one bolt thats a pita but honestly i think with a hook tool you could pull it without removing the cover and put the new one in
