Jeff, How did you adjust the clip ons? From the looks of them there is no adjustments possible available other than adjusting the lever heights. Tell me more on what you adjusted.
Sorry, what I was thinking and what I typed were two different things. I adjusted the levers, not the clip-ons. Suzuki has seen fit to not allow any clip-on or fork height adjustment.
Hell pre-load is hard enough (when your old and can't see) as it is.
One of the Falcons lineman has a stretched white busa with some 1/4 to 1/2 inch plates under his triple tree that dropped his front end down to ungodly height above his front fender. Headlight looked like it was almost sitting on fender. I could not understand how he was doing wheelies on it.
Is that the proper way to lower the front suspension?
Also, any tips on changing out the rear dogbones to 750 bones?
[This message has been edited by byhalia (edited 27 July 1999).]
