Short circuit??
bregt14
I`ll try to explain this in English although I`m not really good at it.
My bike doesn`t want to start.. Here are some measurements:
*Between the - of the battery and the starter housing I measure 12V!
*I removed all fuses. 12 v doesn`t disappear.
*Removed all sensors, 12 v doesn`t disappear.
* 2 contacts off the CDI/ECU. 12 v doesn`t disappear.
* removed ignition swich, 12 volt disappears. measured ignition switch, seems normal..
* Head realais (under seat) chsanged, no changes...
Temperaturemeter maxed out, neutrallight doesn`t work anymore, 3 volt overall when contact is out, 12 volt with contact on...
SOMEBODY ANY ADVICE?:thumbsup:
Yea does seem like a short to the housing, but doesnt that contact the motor which SHOULD be grounded?
I found it out.
The cable between the - of the battery and the starter housing had max resistance..
Problem solved.:thumbsup:
