Jose J Ortega
Hey guys,
I preassure wash the engine case two days ago. Same day I try to start the bike and won't crank. Fuel pump is priming( bike is in neutral) I hold the clutch in the side stand is up and try to start the bike and makes the noise when the battery is low and has no power.
With the side stand down, neutral and clutch in makes a clicking sound. Then it will start.
Yesterday it won't start later in the day I was able to start it fine, then I will do the same thing again.
Could bit be the side stand switch? I hold the clutch ?Thank you in advance
