ok, so i just went out in the garage and was messin with my bike and i noiticed my front brake fluid level was low. i can add brake fluid (dot4) with9out having to bleed the front system correct?
also, changing out my brake pads...... is it really as easy as removing a spring and then the lil clip and retaining pin?? no caliper removal necessary??
i usually dont do my own work so that is y i am curious since i am rather mechanically inclined. i jsut never feel like dickin around with it..... even though i should!!!
