Slight stumble/misfire on low speed acceleration. Thoughts?
JBN
Hey guys, newish member here. Having a very slight issue I was looking for some help with before buying parts.
Bike is an ‘08 and aside from yosh slip ons is bone stock with 4600 miles.
Last month I noticed the secondary injectors weren’t firing on WOT causing the bike to sputter/lag so I pulled all 8 injectors and replaced all seals and screens in them, as well as the fuel pump sock, air filter and a fresh oil change. This did the trick and the bike was performing at 100% again.
Well I went for a ride today, and noticed when accelerating from a stop and very low speed turning a slight stumble/misfire. While cruising/accelerating/WOT it doesn’t miss a beat. It isn’t a horrible miss, more so annoying just cause I know it’s there.
I’m leaning towards spark plugs but wanted to get some opinions as to other possibilities. I know, I should’ve pulled the plugs and checked them while I had it apart doing the fuel injectors but it was an oversight at the time.
I did a search and couldn’t find anything as far as a gen 2 goes, so here I am lol. Any help is appreciated, thanks!
