Sounds good man. Thanks. I just got the bike, and it's completely stock. It's also my first bike, so I'm trying to figure out what upgrades are needed first. Why just the front brakes? What is suspension sag?
Suspension is the most important thing on ANY sportbike, and yet so few seem to know about it(as well as tires and proper psi).
It is having the suspension set up for your weight(including gear).
So the suspension works without transferring most of the motion into the frame.
It is what makes the bike handle. There is no base setting either.
Have a perfectly set bike, turn a couple screws, and handling gets terrible, and vice versa.
Search hear for "Jinkster attacks suspension", or youtube Dave Moss.
The front brakes do the majority of the stopping. Stock, they are in need of improvement. Ceramic embedded pads will stop you sooner. Stainless steel lines will not stop you sooner, but will really improve the lever feel. The rear brakes are good enough as is.
I would adjust the levers up/down, left/right until they feel like they are in the best place for your hands.
First bike? I'de reccomend learning to keep 1or 2 fingers on the levers, and the other 2-3 on the grips. Also have the clutch lever adjusted to engage far away from the bar.
That way you can pull it in/disengage it, and not crush the fingers on the bars, same for the brake. That will help you control the bike better. It's a preference, not a rule.
But, if you let the clutch go too hard with 4 fingers, you don't have alot of grip.
With 2 or 3 fingers on the bars, you have some grip, and it's easier to maintain control.
Practice braking, emergency stops, until you master a very small stoppie.
Ride like you're invisible, everyone is trying to hit you, try to forsee any possible outcome ahead, and do it all relaxed without being paranoid.
Skill will come much faster with a bike that is set up correctly.
Ask lots of questions. Many good folks here always willing to help.
Welcome to the org.
