wickedsprint
So I installed the smart TRE today from Ivans, the one that has a chip to keep the stock neutral map and a smoothe idle. It is alot smoother mid corner after compression braking and then resuming throttle, used to be akin to having a ton of driveline slack, but it is alot easier to make smoother mid corner power adjustments, less abruptness which was one of the reasons I wanted it. Now on to the meat and potatos, it pulls noticably harder in 1st and 2nd, like someone added another 200 CCs worth of torque, and the engine has a distinctly different growl in the lower rpm ranges when opened up. Hammering it in 1st gear brought wheelspin from a 20mph roll and second started spinning also whereas before it did not do it AS bad in 1st and virtually none in second. I am a pretty light rider though, about 155lbs ish. I can say it was worth the money. Now onto the bad news. Cruising at 30-40 ish requires a bit more finesse, throttle is touchier, but more predictable, although steady state cruising sees a very mild surge, like it does not feel as smoothe holding city crusing speeds any more, but just barely perceptible. I am at 6100 feet of elevation for the record in case we have any high altitude fence sitters.
