bpjones
Do I need a additional electrical harness to plug in a Speedohealer and a GIPro/TRE Indicator?
Like Smith's:
Frankenstein Replacement Bolts
Like Smith's:
Sorry...I meant this Smith link:
So so I need one to use both Speedo and Gear Indicator?
Wait, I'm getting confused here. The speedoHealer should plug into the SpeedSensor harness on the leftside of the bike. The Accessory harness shouldn't have anything to do w/ that, you're plugging it into the extra harness on the top right corner of the nose behind the gauges.The GI and SH plug into the bike's wiring, not an accessory power port. That's what the harness does, provides power to items such as radar detectors, GPS, etc. What you're talking about goes into the Busa to perform their task which is displaying gear and modifying the speedometer output.
The GI though needs constant power correct James? So he would need to hard wire it to the battery in some fashion. The accessory plug near the right blinker is an "ignition-on" only power source.,
I dont think that it needs constant power, but it will reset itself if you dont connect to constant power. I dont have my tre function activated, it is set to off by default. If he connects it with the Smith harness, and wants it on a particular setting, he will have reset it everytime he turns the bike off. The Smith harness connects to a 12v switched source. I wanted the Gipro for the gear indicator function alone. I also suspect that it is the cause of my battery dying on me. I measured 1 miliamp of draw on the Gipro hot wire on Sunday. Mind you, I dont ride mine as often as I should and anyone that rides their bike on a regular basis should not see any ill effects with the Gipro connected to a constant 12v source. On a side note, I also disconnected my Gorilla alarm to see how it does.
(sorry in advance for the thread jack)
Did you end up getting that battery replaced?
So you got all that bpjones? If you want the GI to not have to be reset, connect it to a hard line, otherwise you could use the harness if desired.
OK Guys...what I hear you saying is:
1- Use the Smith Harness for my Bell Vector Radar Detector.
2 -Use the speedohealer on the left side in the speed sensor plug.
3 - Run the GIPro direct off the Battery.
Correct?
