OB_easyrider
This is a serious technical question, I am not mocking anything this time.
How does remapping the ICU alone increase HP if the redline has not been changed? Are the current specs running lean or rich at certain spots? Did they do a poor job for the initial mapping? Without changing the exhaust how do they get the extra flow? It may be a dumb question but I thought power was related to how much air/fuel you could cram into the chambers and how high you compress the mixture. Without changing anything other than fuel injection how do you cram more fuel in without running rich and clogging? Or are they playing with the ignition timing? If they advance the timing won't we run into pre-ignition problems?
Tech help over here please?
