sorry one more question...front sprocket removal
txbikerdude
Hey all, sorry for all the questions. Sometimes it seems that the easiest things are the hardest... I am having a b*itch of a time getting to the front sprocket. I got the left faring off enough where I can pull it back to get to the front sprocket cover. I am referencing the K8 manual but I pulled all the bolts off that the manual states but I cant seem to get the sprocket cover off. the manual shows there are 3 bolts on the bottom portion of the cover but I only see 2. has anyone done this before that may be able to help?
Make SURE you get all the bolts out. Once you do, however, it can be a bit of a tussle to get it offa there. Just keep workin' it and it'll pop loose.
--Wag--
