Vetteman761
This is the sound ive been hearing, had a loose spring tightened that and still hear this, is it normal?
something sure sounds loose...…. maybe remove the cover and give it the ole eyeball test... even I could identify metal on metal.... before u end up with a REAL problem....This is the sound ive been hearing, had a loose spring tightened that and still hear this, is it normal?
No deff coming from the clutch area, Ive had cover off it seemed good, but maybe Should take another look,It sounds rough running too. Pull the cover off again and see if there's any evidence of scraping anywhere in the clutch housing/hub. To me with how it sounds along with the exhaust, almost sounds like a valving issue. You sure it's not coming from the head or cylinder? Could be the cam chain tensioner allowing the chain to slap around. May wanna pull the fairing, pull the inspection port for the cam chain tensioner and make sure it's all good.
I do need to synch carbs also, runs good under throttle but when at low rpms bucks a bit, might help on a lot of things?Ok, so your idling is low and the first thing to do is to balance the throttle bodies at idle speed (1200rpm).
It sounds like you have your idle speed at 1000rpm or less, mine sounds like that when idling too low, its back lash in the transmission and clutch is what I can hear, so raise the idle.
Let us know if this helps.
So I just had another listen to that, may be more going on than just back lash, some one else may have an idea? Hope so . . .
Its a 04, and had it off and had one loose, but the video was taken after I had done that.What year is your bike. 08s and early 09s had an issue with clutch basket bolts backing out. Remove your clutch cover and check them.
Awesome thanks bud, will have to take her apart later and check those other things, should have when i had cover off first time, but saw that one loose bolt and assumed that was it, I will let you know what I find out, o yea throttle bodies huh lol yea iam used to my other bike hahaOoh! Another thing to check with regards to the basket bolts backing out...just made me think. If you remove the outer basket, have a look at the springs on the back of the basket.. you could have one possibly broken!!! I was just thinking of the sound of the springs when you have the basket out and shake it. Could be it!
