Dafeimao85
Hi All,
Recently i heard from my local busa community recommending the CR8EIA-9 (default is CR9EIA-9).
I understand the heat range the 3rd alphanumeric
Well according to the discussion and Google, they info was the lower the 3rd number, the better it is for the engine due to less heat dissipated and hence carbon cannot form on the chamber.
However too low will means a hotter chamber and likely to cause pre-detonation and hurt the engine (petrol itself is also a cooling medium to prevent a over heated chamber which result causing spot damage on the piston usually directly on spark plug spot).
The Gen 2 busa manual did mention that it is okay for CR8, 9 or 10. So I am thinking to put in a number 8 plug but just being paranoid will it damage my busa.
Any bro here using CR8 instead of the 9? Any info sharing?
Sorry for re asking this thread. Did search a few thread starter asking about spark plug but usually is about iridium or oe type.
