I inspected mine per what the service and owners manual claims at 4,000 miles. Mines appeared to be fine so I'll leave them in until 7,500 miles comes around. I will stick to the NGK plugs, don't remember the part number from the top of my head though. Hope this helps!
Change them out every 6 k miles. Clean them at 3 k miles. Found ebay seller has a 10 pack of NGK CR9E at good price. CR9E is the OEM replacement plug. Thee is Iridium IX NGK sparkplugs now, not familar with their preformance.
Put some Dielectric Grease inside the coils little dap on end of spark plug connector.
Checking the sparkplugs if their white oxidized use the same plug. If it's dark carbon fouled try a NGK CR8E plug. It's hotter plug. Temps at the elctrodes is higher helps burn off extra carbon.
