Speed sensor wires
BBMykey
Happy holidays to all. I'm installing a "Back Off" module to my rear taillights. I need to know which of the three speed sensor wires is the positive, ground and speed sensor. The three wires are black/white, black/red, and black. I'm guessing black/white is ground and black is positive? Any help would be greatly appreciated.
The back-off module shouldn't use any speed sensor wires. It uses the brake light wire. What exact model are you using?
I stand corrected. It should be pin 6 at the ECU. Tap the Black/Green stipe wire for the speed signal. I didn't consider the BO Hold. I'm used to working with the BO XP and regular BO units.
Thanks for the info Tru. Before I read it I already did it a different way by guesswork. I was already accessing the speed sensor itself. In case anyone wants to know, if you need to tap into the speed sensor output on a k8 it's the black wire (which turns to pink on the other side of the plug).
