Speedo pinouts
bullstarz
Im trying to fit a digital speedo to the bike as for reason mine reading about 20% under and not all all clear when riding. Im looking for the pinout on both Gen 1 and gen 2 looms as my bike is a mixture of both. Also any info on the pulses per revolution on both the speed and revs. Any help would be great, the dash is a Haltech IC-7.
Thanks
I make these plug and play if you are interested. As an FYI, you need to supply 12v and ground to the speed sensor if you remove stock gauge cluster, and the speed input wire requires a pullup resistor etc.
your coolant gauge comes across as serial data (along with gear indicator if a gen2, FI light, ABC mode etc), to get a coolant temp will require an external sensor, or wiring into the factory coolant sensor directly.
