spools with extentions?
dragonbusa
Hey yall, I"m planning getting a set of 7-9" extentions, So what do I do about my spools? I dont want to not be able to use my rear stand. What the solution? thanks.
I had the same issue,
What I ended up doing was to make this, I just rolled the rear tire up on this and it raised the rear of the bike high enough that the rear stand would fit under.
^ quick answer, if you have a stand that you can change the parts out on you could look into the ones that lift from the swingarm.
Pit Bull makes a very nice convertable stand that will lift using the spools or lift on the swingarm rails. Both work quite well. A little on the spendy side but good stuff! Made in Alabama.
I think Randy (LA BUSA) has a double first cousin who's brother in law that's married to his Aunt Eithel own's the place. Maybe Randy could get you a family discount? :laugh:
You giving up on the training wheels?:poke::laugh:
Pitbull's convertable stand works well....
DAMIT BROWN:rofl: I"m gonna give it wirl. If it stays with in a foot off the track yes I"m gonna take the bar off. Any body want to buy a good used set of wheelei bars:whistle:
It will stay between 12 and 18 inches on a good run. Invest in some new clutch packs and some fresh drawers, you will need both while you practice getting your clutch hand right.....
I here ya, ordered new clutch sunday (FBG) as for the drawers:moon: dont wear um:rofl:
The last time I used Fast Bt Gasy clutches they only lasted one pass. All of the material came off of the plates and clogged all of my oil passages and I spun many bearings. I have to completely disassemble the motor to clean it,by a new crank,con rods,bearings and oil pickup. STICK WITH OEM PLATES!!!!
DAMIT! did you soak them before you installed?
I just did a search and i cant find any one saying anything bad about any FBG parts???
