Spring bolt
BlueHaya
I'm outta here!!!!
Does any one know a good low cost location to get the spring bolt for the fairings?
What part is it? The clip that slides on the plastic...if that is it a body shop supply place should have something if you take in an example...NAPA has racks of those items too
if that's what BlueHaya is referring to it's called a "body clip". i just picked up 2 at the dealer for $6 dirty bastids. you should of seen me trying to describe what the heck i was talkin' about to the parts guy. :whistle:
I went to Fastenal and they showed the GM and Ford clips, but had to buy 50....not bad at .45 each compared to 3.06 each at a dealer. I was not sure about the thickness. The GM/Ford was a pretty thin opening and I wasnt sure if they would work.
My AutoZone said they didnt have the spring clips.
Exactly.......
I just received some I got from McMaster-Carr.
They will work, but I have to cut out the little flap on the inside to allow it to slip over the plastic tab. But for .22 each compared to 2.00 to 4.00 each.....I will cut out the little tab.
McMaster Carr Part # 95210A120
(GM 11505596; FORD N623331-S2)
