bajaboy169
what is the best set up for a stock busa with open pipes and power commander for gas milage with the sprockets?
stay with stock gearing and get an overdrive 5th and 6th gear.
Pay attention to "Johnnycheese"! Taller gearing places a heavier load on the engine than stock and may very well suck up more gas. Especially if you are a big guy or ride double.
And sometimes you can improve your mileage (Depending on the load) by a gear reduction to allow the engine to pull the load more freely. I reduced the gearing on my Gen II with a 45T rear sprocket and it actually incresase the mileage by a couple tenths per mile.
And yes, that was after I had corrected the actually speed with a speedohealer on both sprockets.
