you are right i am missing a push lock fitting for the fuel feed line.. already call them about it, and the map sensor included with the kit won't fit the connector....on the secondary injector controler...
well i have the engine completely apart right now waiting for the rods and pistons should be in next week, then i will have to plastigauge rodsfor proper bearing clerance, might do the crank while it's apart....i also order ape main bearing and head studs.... what do nyou guys think of the ape studs? i did take pic. will try to post some soon....
