Macfast
Never Forgotten
I have a 2000 Busa with 28,000 miles. Starter Has not been modified. The starter sounds like it is not engaging will grind a little bit, then catch and start up.
I pulled the cover off an hour ago expecting the worst - everthing looks normal - I thought I would find teeth broken off but everything looks fine.
Tried the starter button with gear off - spins over fine with no noise. All teeth on all the gears look good, no visable cracks in case
Any words of advice ? What could be the problem?
