that does sound right.which way did the bike fall?(fsusux @ Jun. 08 2007,22:21) Sounds like its in gear with the kickstand down.
I belive you only have to turn off the ignition (key) and turn it back on. Then it should start. Thats how it works on a yamahas.(Spike @ Jun. 09 2007,10:24) This begs a question.
If I ever lay this thing down (god forbid) the tip over sensor should shut it off. Is there a reset switch I need to hit to get it running again after I stand it back up? I can't find this in the owners manual.
