Yea probably a good idea.. no warmers here thxI would ask the local track junkies what tgey are running. Are you running tire warmers if so you could run a higher psi because it will not take as long to get to the tires to temp
31 front and 30 rear...cold...35-36psi front and rear HOT...measured right as you come off the track
This is through NESBA (Kevin got me hooked up with them)I run 29 rear and 31 front, but that's with Pilot Powers.
Who's putting on the track day, if it's STT ask the tire changing guys.
But definately ask local track guys...
Do you want me to bring my tire warmers to the Bash for you to use? I am not going to hit the track anytime soon, they are just sitting there... Chicken Hawk Tire Warmers
Tire warmers? you think I need them? I am just running the B group.. maybe a bit of overkill for my first day out?
Do not use tire warmers w/ street tires, gets them too hot. They are designed for race tires only.
Good tire warmers have 3 heat settings
Even on the low setting it will heat cycle the tires for street tires if you can get a good set of slicks that is the best way to go
Street tires are designed to handle MORE heat cycles than race tires
Will be at Putnam.. supposed to be a relatively fast track from what I was told. Sounds to me the tire warmers if not used as easy bake ovens would work (like why warm tires 2 hours ahead? ) suppose I could take them and try both ways? I will be there 2 days and hope one set if tires gets me through the weekend..You probaby don't need them, but it may give you more confidence knowing you are all warmed up ready to go. What track are you going to?
No problem with me bringing them, I just need to remember to pack them up.
Yea but I got a coach that said (and I quote)Uummmm.... You're name is "Bogus" not "Rossi"
