after finally solving my starting problem, ive been chasing a new one... on my bike i have a brand new upgraded stator and rectifier from ricks motorsport electrics. when i put it on last month i checked the voltage at the battery, 14.4volts while idling perfect... now i can barely get 12.8 volts.... my motor was taken apart for a big bore and 08 crank upgrade (i have a 03 busa) and my builder reused the old stator gasket. i checked and i have 0.6 ohms on the 200 scale on my multimeter between one of the yellow wires coming out of the stator and the motor case....witch means the stator is ground. Now my question is, did this damage the stator, if i put a new gasket can i reuse my stator? i did the ohm test between the 3 yellow wires, perfect. did the no load test on it at 5000rpm, i have 70volts, again perfect, tested the voltage regulator's diodes, again all perfect. I hope i didnt damage the stator? thanks guys for the input!
