(mike04busa @ Jun. 08 2007,23:30) how do you change the oil in the damper??? sounds like a good idea.
when I did it ... it was a messy processes... but worth it.
The oil that comes with it kinda sucks.
Anyway... the way I did it was to remove the damper completely from the bike.
Remove the screw from the housing of the damper (the part where the oil is) and work it back and forth a few times (careful,, pumping your damper could cause it to squirt in yer eye
once all that old stuff is removed....
take your previously purchased quart of 90w gear oil and pour it into container large enough to put the entire damper in, but small enough to allow the damper to be completely submersed in the 90w gear oil.
Stick the damper in there and again.. start pumping it open and closed (the screw is still removed.. thats where the oil is going back in) until it flows back and forth smoothly with no "jumpy" spots (jumpy spots are air bubbles). You will be able to see air bubbles coming out of the small hole where the screw goes for a little while.. keep pumping till pure fluid is coming in and out and it's moving back and forth smoothly
After you get it flowing smoothly your pretty much done. Re-install the screw (I did it while it was still submersed in the oil to make sure no air entered to mess up my hard work)
All over now but the clean up... and re-install
