steering stabilizer
GSXcite
Squirrel Master
getting the bike together after the low side crash, and I got to looking at the stabilizer. Seems to have a slight bend on the ball joint end, right by the threads. It takes a slight bend toward the rear of the bike. Steering will go lock to lock with no binding, but I don't want to finish if the stabilizer is bad. Anyone know if the rod should be streight all the way to the ball joint, or do I need to take it off and try to streighten it out.
certainly do not try and straighten it... if in doubt, remove compare to known good unit and replace if it is bent
Im checking for Doyle in the am, but if ive got them still, ones up for grabs ill get back to you!
i'll be there in the morning on Lucy...we can compare it to hers to see what's up if you trust her parts to be normal after having to lug my butt around
