I decided to remove the eyesore warning stickers from the tank and underneath the handlebars, but I've run into a problem with one of the textured plastic panels.
They both came off without much problem, but I noticed there was a small white spot on one. I thought it was some left over adhesive, so I let some WD40 set on it for a few minutes and then and then scrubbed with a soft cloth a little. It wasn't going away, so I then figured it was a slight abrasion from me rubbing on it.
I put some wax on it to try and bring back the luster to the spot and essentially make it black again, but that didnt work either. Since nothing was working, I figured I would just let it be since it really wasn't that noticeable.
I guess it took the wax and/or WD40 to dry 100%, but, once I got it back on the bike, I essentially a big gray spot where I had gently scrubbed. I'm pretty sure it isn't from the chemicals because the spot would be even bigger. It is pretty big though, approximately 2-3 in he's across. So I guess it's just from the abrasion. And something I forgot to mention - I did was the panels after the WD40, so I did just put wax straight on top of that.
I figure perhaps some shoe polish may help, but I honestly don't know. I don't want to mess it up even further, so what would you guys use to restore the luster or 'blackness' to that area?
Thanks.
Thanks.
