Sticker Removal
Magikman
OK I decided to take the stickers of and reflectors are off too.
Now how do I take of the decals without scratching the bike?
P.S. I did do a search for this but I couldn't find anything ... Lord knows I didn't want to have to ask for
getting off stickers.
I used heat, WD 40, Goo Off and several other things. I still scratched my tank a little
Good luck.
Use a hair dryer for the stickers and wd40 will remove any cr*p thats left .
I used Alabama heat index of 107 degrees last week, fingernails (gently) and some sticker remover to get the goop off. Worked great!!
fingernail heat wd-40 perfect combo! no scratches , when i did mine i asked , and a board member who owned a body shop said to soak a rag with wd_40 lay the rag on the sticker goo for 30 sec then wipe away ! worked PERFECT:D
if yah got a "heatgun" for lets say .. " Heatshrink tubeing " .. use that ...or wash the bike many times in succsession
I WOULDNT MIND AWNSERING THIS QUESTION 100 TIMES A DAY , CAUSE STICKERS SUCK ! JUST DONT ASK WHATS A TRE ?
I used the wife's hair dryer and gently removed it with a plastic putty knife. Once it was started, the glue protected the tank from the scraper. Some OOPS to remove the remaining glue.
