bobber
Changed the oil last week . and noticed when i tightened the oil bolt ,it felt weak at the last 1/4 turn. Im not one to over tighten oil pan or valve covers for this very reason. I have a gen I with 8800 miles. Ive dumped the oil at least 10 times, i only put about 1200 miles a yr on it. I noticed that I had a drip or about 20 drops over nite [caught it in a spray can lid to monitior ] The biggest problem of my error is I havent ever changed out the washer which probually helped with the thread reaming. I drained the oil last nite to put in another washer/drain plug if neceassary. The plug looked good but I could see A few loose threads inside the pan hole, I cleaned them out[about 3 half pieaces]. I installed the new washer with a little oil resistant[black label] permatex on the washer [both sides] making sure none got on the threads. I left it set over nite with no oil to allow a better outcome of the cure of permatex. So, my question is , Would a over size self tapping plug work? or a piggyback[ plug inside a plug}. other than pulling the pan as the last option. The plug from what I'm told is a 14mm and looks like to be a 1.25 thread pitch. the self tapper from autozone is a m14x 1.50 which is more of a course thread,they even make a 1.75 . I thought about tapping it,,but you have the shaveings to worry about,even with the self tapper,[but was told to use grease on the bolt to capture some of the shaveings. No where Ive looked carries a over size 14 x 1.25 One guy said you wanted the 1.50 to remove all the old threads/ my train of thought was to keep the same pitch aand go in a little wider and I would be less likely to either go in crooked or ream it out worse. What do you all reccomend and what experince in this..I still have some threads,,but I want to fix it,,hopefully without pulling the pan. And The dealers around here dont even know the factor plug size,,,Looks like a m14x1.25 but i dont know,,I have a m14 x1.50 self tapper and a piggyback m14x1.50 [bolt in bolt] but the outside head is somewhere around 22-24 mm inside O.D is M14x 1.50 on the piggyback,,,, Thanks fellas
