drums_till_I_die
ok not sure if the dyno section is the right thread to post this but i figuerd youd guys know better then anyone .....
i am not 100% on exactly how the electronic injection works on the busa .... but on cars and trucks i know the ecu and injection system can compinsate for diffint parts like better exahst and cold air intakes and differint performance parts .... without any electronic tuning .... inless you get inside the engine and want to change timing or add bigger cams then you have to break out the laptop and usb-to-odbII connection and tune it ...
so my question is can the stock injection/ecu on a 05' busa compinsate for things like a small air box mod , gutted cans , etc... etc..
? or will it just keep the same settings and run lean unless i get a power commander
? thanks for the advise !!!!!
,Justin
,Justin
