lensflare
PLEASE HELP ME!!!!!!
some strage behaviour happens to my '01 BUSA (completely stock)....sometimes, after a long run, when i give heavily GAS, the engine seems to stall, it feels like the rev limiter is set to 5k RPM...
it is the second time in 3 monthe that it happens, and i have noticed that if i turn off the engine, when turning on the key, there is not the usual "zzzzzzz" noise of the pump in action for the 3 seconds, but there is a noise like someone is blowing into the gasoline in the tank with a straw..... - blblbbllblblblblblb -
once stopped the bike in the garage, the following day the misterious noise is disappeared and the bike runs a usual...
the strange thing os that when it has the problem, no "FI" indications are displayed on the instrumentation, the bike seems not to realize that something is going wrong....
before starting the bike inspection i hope someone could help me to focus on some specific points to avoid useless loss of time and headaches...
something says me that it is a fuel pump problem.... because the bubbling nopise i hear in the tank in those occasions seems to be a pump trouble...
i have otherwise noticed this noise sometimes when the tank was quite empty and the bike standing on the side stand... but when it happended, it was fixed refueling.... this time it happened with the tank half full, so i 'm going to run MAD!!!!!
thank you for the help you will give me...
greetings from Italy,
LENS
LENS
