TXBusa05LE
"Jason
Perfect!! I can't ask for better pics than those you sent. I am sending the replacement right now with a couple of set screws. Please replace the two hex bolts with them. The pin I am sending is heat-treated chrome-molly steel. It will work with the stand and the Busa and is 2x as strong. I have never had any problem with it ever since I switched the steel grade. However, it is shorter and w/o a step. You will need to use the set screws to keep it in place. The set screw will do a really good job keeping the pin in place. I know it is kind of confusing right now. But you will see what I mean when you get the pin.
Thanks
Tom"
Thanks
Tom"
