HongKongPhooey
Hi, I need some advice please, been going through the other topics and haven't had any joy...
I fitted a braided hose to the clutch on my gen 1 (07) and bled it up. It bled up nicely with a mity vac..... but..... Now the clutch engages/disengages with about 1-2cm of lever travel. Maybe some of you like this but I prefer the standard clutch 'biting point' and found this a bit extreme, almost to the point of slipping. I took it to a mate who runs a very good bike shop and he said that it was ok in that it isn't a bleeding problem as the clutch wouldn't engage if there was air in the line, mine is enaging too soon (too efficient)
I took the braided line off and fitted the standard one again but now this too has the same biting point.
I've tried it with dot 5 and dot 3/4 fluids with no change. I've had to fit a pazzo lever (well a Chinese copy) so that I can adjust it right back to near the original biting point (number 2 adjuster, would use no.1 but it doesn't activate clutch switch!!)
Short of leaving some air in the line I don't know what else to try.
Any suggestions please guys?
I am here: http://maps.google.com/maps?ll=51.903129,0.331268
